damn, just had to re tie the boat up, this wind is making it swing hard core was bending down tie in back up, and getting soaked by the waves crashing into the pontoon :)
Dan how much for a .82 housing and how much could i get if i sold my 1.15 housing.
I'm pretty sure they will exchange the housings plus cash their way. Might cost you $150
I can check for you tomorrow if you like. How many K's on the 1.15 housing?
And is it a 1.15 or a 1.06?
Sounds good mate :) , if thats the case order one in for me thanks.
On my receipts it says 1.15A/R. I think its done about 20 to 25000 km.
Finished modifying the std rb25 fuel rail. Converted it to twin feed. See, thats how you save money on buying a billet ally rail and then have to change to top feed injectors. Keep the same injectors and get a flash big hp supporting rail without having to buy it! Probably cost $30 bux in fittings as they were s/s speedflow. 30mins in labour time, drill and weld on fittings.
The photos were before i cut the std feed off and welded it over. But it shows the three -6 fittings i tigged on. Rail feeds have gone from 6mm to 8mm now. Should increase flow abit.
yeh your right..it does fully look home job like...but we didnt want to change injectors...new rail say 200bux a set of top feeds around same cc probably another 600-800bux
Or $30bux for the fittings. I cant charge the race car a labour fee either...so yeh. I think my old man wants it to look full backyard style...give off the homeless look. so when we win it doesnt look like were pro in anyway lol.
the extremely loud gearbox whine and the mega brakes sorta give away that look :)
ok i take my comments back now :) ur allright mate.. i personally would have taken the easy route and gotten a billet.
Mickey T's arrived and clear the guards. WHOOOOT! :)
what size rims and offset.. ur not using GTST are u?
i can assure you if we hadnt already gotten a set of 850cc sards then we would have gotten a billet top feed rail and some descent top feed injectors.
What rules stipulate that you cant be a backyarder if you have a dogbox and alcons?
Oh, heard that autronic have now come out plug n play for rb25 and rb26 with some sweet built in thingys. Like you dont need the cdi apparently as its got something similiar built in....dont know if you still need the trigger disk or not though. I could be wrong, but these are things ive just heard.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
