hmm, dan can u recommmend any places for exhausts?
and do you think its beeter to go buy a full turbo back zorst, then go to a palce, of let them do it all?
It really depends on your budget and how much power you want to make.
If you have a bit of money, buy a CES dump pipe and CES catalytic converter. Then buy something like a Trust exhaust cat back system and just bolt the thing up.
Kakimoto are pretty much the only available exhaust system that is available for your car that can be delivered. A cat back system is approx $880. The CES dump, cat and custom 3 inch system that I did on another 34 netted him with 175rwkw on an otherwise stock 34.
The CES dumps I think I can buy for $500 and not sure what the cats are worth but they are a slim profile to fit under the 34.
Regards, Daniel
I need to stop doing so much work. I need to get my car back on the road. Nearly have all the bits to get going. 800rwhp should be enough I reckon.
But then again I might add some blue bottle throttle as well.
anyways Im gonna go do my oil change im heading down the coast in the morning
hey marki i have heard some shit about not regapping NGK iridiums but i have got a bit of misfire since i put em in and the previous plugs just ngk coppers were gapped down to.8 with no dramas
are these iridium things ok to regap?
why dont u ask matt.. apparently i knw f**k all bout cars.
what gap are they now. if they are .8mm they will be fine. just a boosted car normally blows the plug spark out. it does on my ld gtr and on a s14 i worked on today.. put some .8mm gap ones in a no missfire.
ive gapped platnium and iridium with feeler gauges and work fine.
just dnt be too rough
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
