Shane: Noel and I were chatting about the projects and time taken to complete them tonight. It all boils down to one thing - PREPARATION.
If you start out blind and just think I want this, and just add bits until you think you have it right, you will always be disappointed with the hack of a job at the end of the day and you will always spend twice as much and it will take twice as long.
Before any great project you have to sit down and write out your goal. Write down a list of EVERY item you think would be needed to achieve that goal. Then take it to someone who knows what they're on about (not some cash junkie workshop that only wants to sell you parts that look bling or might be bits he has to get rid of coz they been on the shelf for a while). Once you have all the information you need, take your list to another place and get a second opinion. If there are differences in opinion, ask why, then go somewhere else reputable until you get two well known and good quality workshops to agree on what it will take to achieve your goal. Then you proceed with a plan of attack to get everything done.
Once you have broken it down and know what you need and how to go about it, all the legalities etc. , then you will have a smooth operation.
Either that or just FRIGGIN ASK ME IN THE FIRST PLACE!!!!!!
Then you wouldn't have to spend so much money on crap you didn't need.
Yeah BOI!!!
lol ill walk on him.
lol!!
hows my fist sound..??
I dunno, hows a criminal record, and an expensive civil suit sound to you?? Honestly marki, we've been through this before. Get over it.
dnt worry its not just me i knw of others that arnt too fond of u. its just the world as u say
What, you know a few people on this forum who aren't fond of me? How genuinely sad this makes me. I know people who think the same of you, does it really matter at the end of the day? No, not really, unless your seriously vested in making everyone on this forum like you. I don't know what your social status is Marki, but I don't depend on this forum for friends.
DAN, whats the total?
Dunno mate, the lift pump was $130 but the filler I won't know until it arrives. The express air freight from USA he said would only be $50 and will take 3-5 days. But not sure on the actual cost of the item. Just fix me up when it get in.
K brudda?
lol!!
What, you know a few people on this forum who aren't fond of me? How genuinely sad this makes me. I know people who think the same of you, does it really matter at the end of the day? No, not really, unless your seriously vested making everyone on this forum like you. I don't know what your social status is Marki, but I don't depend on this forum for friends.
I like you mate.
And that's all that matters.
Yeah BOI!!!
this sounds familar...oh that's right u've told me this before :)
well u know where it's heading now, plus i dont want a half assed job parts & fitment wise.
K brudda?
k, i'll transfer 200 and i'll fix u up the rest when the stuff comes in (pm bank details mk)
P.S dan that fuel system price doesnt include the shit i've fooked up on lol, that's the price for all the pump,s filters, lines, fittings, tank, injectors, fuel rail etc etc
Pajero 3.0lt V6 is just way too quick. Like OMG u need overdrive off to pass people quick. f**k me, watch out M1 IM BACK
patty go alrite eh? mite have to give u a run on teh M1 on my pink pushy :sorcerer:
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
