I made soup
i had tuna pasta.. but lunch i had a deluxe burger at sizzler.. and it was good and fatty :domokun:
i need to start looking at puting together a motor on the side as mine prolly wont have much left in it once it is boosted
is it cheaper to do a 25 or a 25/30?
lets just say i already have a spare head and a choice of either block
its going to cost about the same to pay a builder to put either package together rite?
and approx the same for all the parts: forged pistons, rods etc.
i would guess the 25/30 will be more expensive as i think the oil lines or something dont line up proper with the head.. dnt knw exactly nor do i care.. SKYRINEs lol
much of a muchness really....might cost more to match the 2 together with a 25/30....but will get more power from building it, then a 25....be about the same strength i guess.
drop shanef a pm he is building one. he will know
hi rohan
sarp marcus
yeh but the thing is its going to be preety simmilar price really and at the end of the day the 25/30 will be more fun and have more potential
I shal take pics of my sausage for you all
Evening all
yo homeboy!!!
touche....depends if you want it or not i guess...i am just going a slightly bored 25 block and flowed head, cams etc...blah blah
should be nicely noodled
Joshwa....whats wrong with tuna??
link dont work <-- dont listen to him....farken does now
on that bombshell i am going to bed...
need sleep
cya in my dreams boys......mostly you nismoboy...you cuddle bear you..
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
