I made soup
i had tuna pasta.. but lunch i had a deluxe burger at sizzler.. and it was good and fatty :domokun:
i need to start looking at puting together a motor on the side as mine prolly wont have much left in it once it is boosted
is it cheaper to do a 25 or a 25/30?
lets just say i already have a spare head and a choice of either block
its going to cost about the same to pay a builder to put either package together rite?
and approx the same for all the parts: forged pistons, rods etc.
i would guess the 25/30 will be more expensive as i think the oil lines or something dont line up proper with the head.. dnt knw exactly nor do i care.. SKYRINEs lol
much of a muchness really....might cost more to match the 2 together with a 25/30....but will get more power from building it, then a 25....be about the same strength i guess.
drop shanef a pm he is building one. he will know
hi rohan
sarp marcus
yeh but the thing is its going to be preety simmilar price really and at the end of the day the 25/30 will be more fun and have more potential
I shal take pics of my sausage for you all
Evening all
yo homeboy!!!
touche....depends if you want it or not i guess...i am just going a slightly bored 25 block and flowed head, cams etc...blah blah
should be nicely noodled
Joshwa....whats wrong with tuna??
link dont work <-- dont listen to him....farken does now
on that bombshell i am going to bed...
need sleep
cya in my dreams boys......mostly you nismoboy...you cuddle bear you..
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
