too much pasta makes you fat
its big bowls too like 12cms high lol..
ill work out tonight to the tune of men at work... lol
now he might get a 3071R... u think the 3071R will be fine on a FMIC fuel pump exhast std ecu car on 10psi :D
Disco FTW. Throw that 71 away!
HI DAN.. prices please.. want asap
correct me if im wrong but isnt a 2871R a disco potato highflow.? and 2860RS is the smaller one..?
thats what i told him, but no he wants something bigger...foo!!!
i want to go home.
no u didnt.. jump band wagons much :D wuv u
You won't get fat Mark, 1. You're AZN, 2. You're young, 3. You got one of those friggin super rediculous fast metabolisms
Having a fast metabolism means you'll likely never get fat or even "big" (unless it self corrects later in life), you can build muscle through mass amounts of protein and lifting big weights on a constant basis, but you'll never be huge.
Disco 0.64 $13** inc GST (available)
Disco 0.86 $13** inc GST (available)
2871 -2 0.86 $13** inc GST (EX Sydney - Tuesday)
Euro FTW!!! Nice work Jay!!!! Let the fun begin!!
The interior was NOT as clean as the photos in the ad suggested so it's going to need some love, but mechanically it's great. Pulls speeds I should not admit to very very very easily.
the problem with having a diet of protein and lifting big weights is, if you have a fast metabolism, as soon as you stop/slow down your workout, start a sport or do anything other than continue what you're doing, you'll just go back to the way you were lol...thats why I just go to the gym every now and again, eat a decent diet etc
ok dan what should a S14a with lil mods get.. just want something thats good and makes more power in the future.. i think 3071R is over kill for him... cause i dnt think he wants 250 like i do
You can make 280rwkw on a Disco with SR20. The 2871 is slightly larger and nowhere near as responsive.
Depends on what lil mods he has. FMIC, pump, injectors, zorst, AFM should net him 250rwkw.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
