yes Marki SR's are side feed too, same as RB25's...
S15 have like 470cc injectors, so it could be a cheap upgrade for an rb25, however when i was in the market it was hard to get a set of 6 as everyone wants to sell 4.
Plus for the money I was able to buy a set of 6 nismo 550cc units brand new, which was far more fitting to my application in the end...
BTW Do you have a name for that tint joint???
dnt knw.. go for a drive on logan rd down at the gabba just next to SS toyota and ABS is the tint place.. i have a feeling its called tint mart..
I think only JDM s15s have that size injector
from memory the S15 ADM is 440cc
man im just gonna go with the 740cc nismos screw the expenses.
Your a nerd mang
UR EMO
+1
ur white and a red head..
Sif Halo 3 is teh bestest game for the 1337. Halo 2 was harder.... ;)
halo 2 was a failure much like the R33 GTR compared to the 32 34 bahaha..
i find myself playin halo 1 more with mates than halo 2.. better story.. but 16person matches and 4person co op in halo 3 ftw.
my gamming doesnt go past msn uno
checkers now bitch
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
