andy for example take this S13 [email protected] 365rwhp@19psi thats 280kw... even a 350kw GTR has troubles pulling that.
it is a street rego S13 its actually a QLD car too. http://www.nissansilvia.com/forums/index.php?showuser=5415
Lol, I raced him in the old 911 when his silvia was running like high 11's. He beat me :D He was pretty cool though, gave me respect for rolling so low
pretty sure mark and russells gtr which at the time had about 380kws ran a 10.2 @ something stupidly fast. To say a 350kw gtr struggles to do sub 11s is a joke, if its not then the driver is.
My RB56 will dominate all!
dont make me bring out teh almighty gtr :sorcerer:
challenge accepted.. shall i tell my tuner to limit it to 240kw..? a nice fat torque line would be noice.
INCORRECT.. S13 is 1170kg and the 180sx is 1220..
i believe it is..
u dnt count.. i need nawss no this will do... no lets make it two.. and dan i need it by tonight.!!!
but in all seriousness. the new car is costing too much so i will have power next year :D
but we shall go drags together :P
its snot all to do with how powerful a car is, it has to do with how quick it is....from a stand still the one with better response tends to make it quicker somewhere....but thats my opinion.
i'll spank you all...!!!!
f**k you jus get more and more full of shit all the time!
this is taken from the nsw drag thread
T04GTR: 11.3@122mph r32 gtr
this is a friend of mine and on his old set up his best ever power was 290awkw
all this talk of dyno figures is a load of wank anyway there is so many farked reading dynos out there
driver ability and setup is the key dont worry about the number it can spin up in a workshop - take it to the black stuff!
This will only work on a downhill, the laws of gravity prevent your car moving up an incline without an engine...
piss off squizz, that was for shrek/andy/noel/marki to bite on, not you :P
euro trash doesnt rate around here Squizz, fark orf or lazy bastard and rhino will take you to the cleaners. (they have a history)
And Mudcrab, You are becoming like 40 grit sandpaper on the head of my cock. Very boring very fast. Shut your stupid f**king piehole before you look like a bigger dick than you already do.
I've raced Lazy-Bastard many times, I'm still yet to see said cleaners.
I've owned 6 imports before getting the M, and I can't see myself going back any time soon.
There is a common theme emerging in your posting. You seem to like phallic references, is there something you're subconsciously trying to tell us?
it's prolly just me, but ill take a wild guess and say its something to do with this bein a skyline forum...
A skyline forum you say? Damn I wish I had paid more attention when I was here when SAU all started...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
