this is ghey i was so excited about my new pink bits
can you even run a 25 without the cam gear cover anyway? Im getting the sinking feeling I didnt think this impulsive buy through lol
yep.. but do u like shit going down ther..??
yeh u can. u just gotta put a spacer in behind the CAS to imitate the thickness of the cover, or ur CAS wont work properly.
u know how to set the new timing belt up properly?
thers a proper way..?? oh do tell im interested.
/subscribes
Yeah i loved the 2 x 350z's are the start and the red R34 GTR GT500 car... OMG
The first Z33 was pretty cool also, chassis number 000001
The old silvia box car, le mans style looks funny, and ive never heard or that 390 gt1, probablly cause its the only one ever built...
haha yeh its pretty straight forward
tips - before you start, make sure uve got it on TDC ( u can check for tdc by lining up the 2 white marks 1 on the harmonic balancer the 2nd on the lower engine cover), and dont go moving the crank or cams when u remove the belt
guidence people - cause i always seem to get myself into trouble:
PFC Boost controller New in box $200 posted to brissey
are easy to play with on the comander?
can i buy from u... wher u find that.. wouldnt mind one for the 180sx
i assume so, never acutally played with one.
my philosiphy on ebc's is that if u can get one that bundles with the ecu then itll work better than a stand alone
only if it interfaces..
im almost certain they interface with comander as thats what you use to set bost change shit around
I will sell you V1 AVCR for $170 :D
whoretown goes off on on fridays aye
:D
yes shane :rofl:
could that even be possible?
not sure, hence why i asked the question :wub:
I will sell you V1 AVCR for $170 :)
dont listen to marki, he'll just confuse u lol
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
