I do that with car yards. They think I have money so I blow hot air up their ass. If only they knew I was killing time.
Find any u like?
I just wanted to compare 6, 7 and 8 side by side in the flesh, all the cars were over priced so i will be importing one myself, After consultation with Anna and Noel it was decided that the EVO8 is the best package, we decided the 6 was the toughest looking but a bit too old so the 8 had the best balance of newness performance and looks, the 7 smelled like a family of monkeys was raised in it so that didnt help its case lol
you females are making me sad now......talkin about selling and all that and i am just building....you not that older then me either... :)
Dont worry we are not getting out of cars all together...just getting into better cars :wave: ha ha
GO EVO 6.5.....best set of drive train IMO. They made a good one with that.
too old now days, I am over old cars, The EVO MR is about as fast anyway and has better suspension :wave:
It does?
i haven't research them. i still prefer the scooby looks though.
they are just a hinderence, and they always fail lolz
they fail in old cars,
I drove 1200km this week, I dont care if i dont win everything I enter, i want my car to be comfortable and fun!
ur getting soft in ur old age :wave:
nah but if thats what u want then go for gold
After a while of driving your car around you will get it :(
fun for a while then gets a bit old!
Turns out the 8MR has a lot the the 6RS gear anyway! Same turbo at least, rated at 385hp!
so same power with a bit more practicallity, noice
After a while of driving your car around you will get it :wave:
hence the need for a daily :(
from what ive researched, the 6RS has the better rear end i.e it wont break as easy as the newer evo's. and the newer ones are 'dull'
Screw dailys if i had one i wouldnt drive it anyway why drive a crap car when you have a good one? Just make the one you have good for all occasions!
Yeah cause it does not have the AYC, the AYC diff is a bit weak over 250awkw...i wont be taking it beyond that anyhow as the rods arent that safe beyond there either (except for the 500hp stock one i saw the other day :wave: WTF )
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
