yeah i see what u mean josh. but ther is a compromise with garrett.
anyway im thoroughly enjoying hearing my bro and his GF fight in the next room.. that shit reminds me why i dnt get a gf
Incl the sponsorship money that car owed $100k, Incl car cost. Compromise's were done else where which lead to f**k ups, which lead to that stupid blowout build cost. Never again.
http://www.youtube.com/watch?feature=relat...p;v=0yfXymnOXl8
holy doley
yeah i got ya joshwa. if u got the cash i would use only tried and tested proven parts. and tuning.. but if u dnt just using what should work should work :P
I don't like no name turbos. I like things that come from a company with lots of RnD. I wanted ball bearing which at that time Trust couldnt offer me
dady paying bills = who cares how much it costs lolz
People know alot more know now though, parts are cheaper these days and your not paying to be the test pig anymore.
So i guess in a way it was a bench mark for back then
fooken oath just look at my car lol
sponsorship...tell me more?
f**k off, i need sponsorship before you :P
Your about the 11thy billion person to ask...
"Im going to build a car that does X, it will be at X events, I will in return offer you X publicity from being at the track X amount of times and enter X events, plus as it will run or do X it will have a write up in X mag with X readers" - "You want your name on it"
f**k off, i need sponsorship before you :rofl:
lol..
i got one :rofl: if u focus on a singular event u get these things
sounds like a plan
i just said.
Hey. i need tyres. ill put ur sticker on my car and hand out ur cards at the track and around the place if u sponsor me..
OK:)
lol..
sounds like a plan
i just said.
OK:)
i need a little more than just tyre sponsorship marki
I’m just generalizing; if you want real sponsorship treat your car like a business, as accentually it is for the people giving you products or money
yeh i've been lazy. if u help me write something up i'll give u some coin for your troubles...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
