wooot ok so
would there be any problems with hooking up a rb25de head/3L with my rb25det powerfc?
that built motor from RIPS is a rb25de head so no vct the owner recons i would need an r32 ap engineering computer or remap the 32 computer he will supply with the motor at no extra cost what are your thoughts also is it true it will use top feed injectors? and I think i heard that the cams slightly differ from the det - true?
dont tell shrek im still thinking about the 25/30 he might hurt me lol
wooot ok so
what head is on the rb30? r32 or r33? r33 heads have slightly bigger cams (see pic below)
the r32 rb25de head has smaller ports than an r33 rb25de or any rb26
the r32 rb25de runs top feed high impedence injectors. r33 rb25de head runs side feed high impedence injectors
N/A valve springs dont like big boost. cams & springs are interchangalbe for rb20det items
too late, he's prolly already read this lol
edit - Might help if i add the pic huh :P
nothing a bit of porting cant fix. plus both r32 and r33 heads have the poo valve springs (being na) but i believe guys have onyl had issues up around 20psi.
i reckon r32 is the better head if ur not gonna use the rb26 head caus of the no vct. plus the 32 ehad is top feed injector already (better selection)
hmm yeh well i guess depends which way you look at it aye
rb26 head would be nice! but $$$ sill considering that built motor from RIPS just trying to get my previous employer to cough up some of the cash he owes me and all will be apples!
one thing u need to look at if u put it in ur 33 is the std plenum clearance to bonnet.
options are either:
a) modify engine mounts and drop motor
or
b) get forward facing plenum
i'd go b, as itd help u make more hp :P
I can. Tourquing up a set of stock GTR rod bolts when one let go 20ftlb short. New set delivered and some were a fair bit longer on the old ones so glad one snapped. So much for all the folks think they are fine to reuse.
Dano, I run a 26 head in mine on a 25 PFC. There is plenty can be done to overcome the small issues.
And that motor has standard internals?
Can anyone say stretched rod bolts.
ive gotta say i disagree with you mr monster. rob has a damn good rep with his motors and if they are run as he has specified they dont break.
however i do remember him saying the std bottom ends he says to cut the revs at 7200rpm
taken from his site
RB30 Stock internal bottom ends start at NZD$3500 (suit up to 600hp and 7200 rpm)
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
