if those whom collect the dole cant buy drugs then what is one to buy???
technically their supporting an industry which intern supports the need for jails, lawyers, judges, police, re-po men, trailer rentals, vn commodores... :blink:
what level is your character?
mines a level 98 dragon master...
good choice of characters....you just gave me an idea for my book!!! cheers.
my character is
Lvl 95 - Dragon Knight.
why 95...cause there is always more to learn.
Geeks in popular culture
In 2005 and 2006, the former WB Television Network (now The CW) ran a reality game show called Beauty and the Geek, where "geeks" try to share their knowledge with "beauties" while trying to learn a modern style from them. The show returned in January of 2007.
Comedy Central ran a game show named Beat the Geeks from 2001 to 2002. It featured contestants competing against a movie geek, television geek, and a music geek, along with a special fourth geek. The fourth geek would have a certain area of expertise such as Star Wars, The Simpsons, horror, Star Trek, and comic books.
The IT Crowd, produced by Channel 4, focuses on the shenanigans of a three-person IT support team located in a dingy, untidy and unkempt basement. Moss and Roy, the two technicians, are portrayed as socially inept geeks, while Jen, the newest member of the team, is hopelessly non-technical.
The show Freaks and Geeks explores the social conundrum of new students adapting to existing social norms. Geeks were shown to be interested in Star Wars, Star Trek, Dungeons and Dragons, Saturday Night Live and related actors, Monty Python, AV club and Atari. Members of their group acknowledged being different from others for their interests, looks, intelligence and lack of social skills.
http://en.wikipedia.org/wiki/Geek
u had to google RPG's? lol
my friend, just cos ur a level 12 plankton doesnt mean it isnt fun :(.... keep training on the shores b4 movin out to deeper waters
yes there is always more to learn
(that merc is awesome, cept the navi sucks ass)
Edited by RusH_
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
