got torque????....
and no revs!!! ;)
jk..farken monster!!!!
lol
myeah mine wont be doin over 7k so i guess thats about the same really.
oo that should flow really well but still have some nice response. it will be interesting to drive against you on track of course.
softcock, rev it til it stops making power...
im probably set my limiter to 7200 as thats what robbie (RIPS) recommends the motor is built for
would be good to have a built 25 reving to something spastic like noels but Im sure my wallet has so far been considerably less damaged than noels!
how many rb30's have died from over revving? i havnt seen any
minell be making power upto around 9000-9500, im confident itll be happy at them sort of revs
You're going to need to make some oil gallery modifications if you want to run it at 9-9.5k and think about buying a forged crank.
The RB30 isn't designed to rev that high reliably especially when you are going to be making 700awhp.
Speaking of which, I need to talk to you about those modifications you will need to make....and it's not doing any dumb shite like knife edging the crank.
we need to talk...
Hey Col what is the go with the user sigs?
Mine is cut off at the last part of the pic, it is one whole pic and I have noticed quite a few others with halve a line of text at the bottom.
yo shane you back on the 3L thing - just trying to make sense of all that went on in my absence lastnight?
ive never been off the 3l thing lol
speaking of such, 3hrs of machining to go on my girdle, i hate weekends and public hollidays :D
try installing ie6 - it dont like ie7 and the smart cookies of sau reduced the sizes of the sigs - genious' :D
:rolleyes:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
