Some of the reviews HERE and HERE. Tacker hardly goes easy on them too, running full slicks in 40+ degree heat. The v8 supertaxis even have to change their brake setup when they run there due to the heat. For the price they look like a decent kit.
thanking you simon
i knew they were there, i just couldnt be assed finding them :)
Yeah i have always loved bikes for speed and agility, but fark its scary when some smuck pulls out in front of you while your cruising along...
As for Evo's i guess its all in the way you dirve it as to how long the diffs and gearbox's last, however buying second hand im sure they have all been flogged hard...
i agree its all about the way you drive it.....but if i have an AWD I want to make use of it
In short there may be 2 skylines in the garage again soon
lol, cars are more agile than bikes, they(bikes) have to slow down heaps when cornering, not to say they arent cool!
also more dangerous... for the rider that is, i wouldnt mind gettin a bike (and bike license) for the pure acceleration! :)
Edited by RusH_
yeh Im gonna do mine before the rules change just in case i want to get one, at least then I can take my bro's new Gixer for a spin when he wants to go posing in the skyline
I think the main thing is there will be a restriction on the first bike your allowed to ride no matter how old or experienced you are just as thr current 17yr old learners have to start on 250's
me riding a 250 that would be a sight poor little bike would be screaming its tits off at 60kph
Yeah they will also be a minimum number of hours needed to get your licence, so no more doing a one day or 2 day course and getting it...
Also most fo the Q-Ride places will put they prices up quite a bit to cover the higher insurance after a Q rider was killed on his road test in Southport last month...
So the system is changing, for the better i must say as its far too easy to get your licence atm. But that said go and do it now while you can do it quicklly and cheaplly...
That said ive had my licence coming up 9 years in June and ive never had an accident on my bike/s its all about how you ride it and how you monitor other drivers behaviour...
I did my licience under the old old system where you had to go on a supervised ride with a transport department officer, was not easy but i got it first go...
The old system was if you stuff up once on the test and your gone, have to come back another day and try again. As where with the Q-Ride system you keep trying til your competent...
Congrats mate, there's nothing like driving your own GTR for the first time but FFS, get an insurance cover-note on the car BEFORE you even drive it home. Can be done on the phone, 28 days to pay etc.......
Enjoy!!
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
