what happened with your 34 markus?
saw something about it on fb...
Over the last 4 months I've built up a mean 26/30 and it's all ready to go, except somehow the original key with the NATS (Nissan Anti Theft Chip) in it went missing.. So no worries, I just ordered a new one in from Nissan and had the car towed down the road to Metro Nissan to have it coded.
After having the car for almost 5 working days the guy calls me back up and goes "Sorry mate, we can't do it, the NATS IMMU (Immobilzer box) is faulty (It was DEFINANTLY f**king working when I took it there as I could communicate and pull codes out of it with my Consult) and we'll need to replace it, so it's going to be $650 for the box" to which I replied "lols, don't worry about it, I'll just come pick my car up" to which he retorts "ah, well we've already done 5 hours labour on the car to get this far, and it's $130 an hour.."
GOOD TIMES! I ended paying 1.5 hours labour, plus the 800m tow truck ride there and the 800m return ride at $140 each way = $475 to come to the conclusion that they don't know how to f**king code a key in EVEN though I supplied them with the manuals.. ARGH!!
Lesson learnt. Anybody got a gtr Vipec they want to sell :P
damn... thats a bit shit
like paying twice for a hotel room and getting told sorry no refund til we fix up our accounting system...
then charging $34 for a shit buffet breakfast...
anyway the weekend was alright... :banana:
lol I get my bf to cook it.. I eat it. Pretty good deal to me! Seriouy ppl Aldi store roast lamb is good! The girl at work were raving about it so we tried it. YUUMMMM!! Now all I need is dessert... Might get my boy to go for a drive to pic some up :banana:
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
