What the hell ?
I bought some anti-oxidant vegies ( by mistake ) for chicken soup and these things that looked like broccoli fell apart and have now made my soup look like some weird dark green goo
What the hell are these green things of doom ?
In what world are you going to get 400awkw with 5k? The Z tune has a lot more to it than just throwing a load of branded parts in. They were all stripped back to a bare shell and everything was completely rebuilt. After it was all spot welded etc. The amount of labour in building a car like that is ridiculous.
Would anyone with a Z tune swap it for a 35 though? I doubt you would get a z tune for under 400k tbh.
I would buy a Z tune if I had the cash.
Who said anything about ztune? That car on advertisement is a M-spec NUR. Not a ztune. I know how the ztune is built. And some sources told me that car was brought into aus for less than 200k and now sold to Greece for an unknown figure.
Tristan: You have fail you notice the fact that I'm running way lower boost (16psi) than what I am suppose to be running (22psi). I thought the redbum in you has long disappeared along with the thrash he left behind.
Think about it logically if I'm running close to 90% duty cycle on injectors with 16psi why wouldnt I hit 300awkw when I run 22psi at 98% duty? If I really need to, I can just change injectors and get a fuel regulator. If original boost was at 10psi and by going to 16psi I get from 165awkw to 255awkw, I think an extra 6psi for 50awkw isnt too over the board yah? The N1 turbos or GT-SS should be ran between 20 to 25 psi anyway.
Colin: I'm not saying 400awkw with 5k I'm saying you dont have to spend 50k extra to get 400awkw. Considering the 34gtrs are more refined than the precendents, remember the topic is on the 34 Mspec NUR not just an mspec. The NUR engine if I'm not wrong is equivalent to an N1.
I know a guy in perth that has a vspec 2 nur running slightly over 350awkw with what I said, ecu, ebc, injectors, afm and fuel pump.
lol im not talking on behalf of redbum, i just recall you claiming you will make make 300awkw on stock inj, and myself and others saying that you'll need bigger injectors - that is all
Nah. Like I said before, proven and done before (2 33 N1 owners). However, everyone is right about fuel. I WILL need more fuel if I want to run higher power down the road, that I agree. But if you have absolutely no plans for anything more, why bother? Same concept as why I dont wanna get a dejetro or vipec. If you dont need it dont get it. Its only when you have the mentality of "oh its only a little bit more extra, maybe I should get that" then you'll end up spending a lot! Same deal with Maccas' upsizing! Doesnt work for me :blink:
Same thing with launching gtrs at 7000rpm. What was the response when I mention that? If you remember.
ps: I lied, I launched 3 times at that kinda rpm and ran 4 times...
+1
its the same as the electric motor principle, you'd understand ur an elec engineer. why put a small elec motor to do a bigger motors job as it will put undue stress and cause it to wear prematurely. and why put a bigger motor to do a small motors job as it will run in-officiant and cost you more. same principle applys to your injectors.
in your case your injectors at 22psi (98%) is the small elec motor. hence why your tuner has advised the 16psi.
+1
Nope toooo serious for me at the moment
I'm out
Tuner didnt advise 16psi. I SAID MILLION TIMES. Its not holding boost for some reason and I suspect actuators or ebc. Which I found out later that the apexi ones are shit. He told me he's got another customer running apexi got the same problem too but when he switched to evc 6, problem gone.
Anyway that said, I still think I'm right about the achievability of that power with stock setup but I have fallen. Next mod after suspension is injectors and ebc or fpr and ebc.
no you said with your current set up you'd make it
enough back peddling, im over the 300kw discussion
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
