You've been coming out with some doozies over the last couple of days Brandon.
suuuuuuuuuuuuuuuuuuuuuuuup dan?
so er...Hello? Anyone in here? much going down?
im here :rant:
epic storm going down atm her in indro - lights flickering n shit
It probably should be merged as well, it essentally doubles up on whoretown as well
mate just got off the phone to greg at gktech they have new radiator bottles coming in on the 29th - wana grab a couple? save a little on postage?
Lets get that shit done then. Get some more people in this here empty vessel.
im here :rant:
We had our big storm already. Pissed it down and cracked one of our down pipes. fun times ahead for tomorrow. Tristan you coming tonight?
how much are they asking?
umm they are $39 each - havnt looked at postage - probs $5ish each i guess
na mate no deal from me
You suck. What's the news on the 180? Bought all the fuses I needed for the 31 yesterday and had a fiddle around with stuff. Needs epic rewiring so not looking forward to that. I think I'll do it after christmas.
will have to consult with Anna and see if she wants it, when do you need to know by?
no rush bro - i just bought on 2nd hand on boost for $10, so anytime man - probs after new years? (depending on how shit this 2nd hand one is :rant:)
180 is chillin, had a whole bunch of stuff delivered today :(
some parts are chilling in customs - should be good to go tmr :happy:
and engine mounts should be here thursday, HOPEFULLY
nice mang. Still need to sort out a cat for the 31 and then once all the electrics are working will get a rwc and register it. then i can gut it, minispool, s13 coil overs and turbo and then away we go. hopefully it will be all finished by the time I get my license back haha.
Col - Fair question mate, and yes it's something I'm already looking at.
The main reason that thread wasn't gone a long time ago is partly for the same reasons the BR thread stayed for as long as it did, but also that they're a good two hours north so there was some justification in having the separation. From memory that's how it was looked at last time it was discussed anyway.
But yes, I agree that realistically the chat in there should probably be moved into WT as well. They do have the added complication of being well out of the Brisbane metro area but talking crap over the internet isn't really dependent on location is it, lol.
In any case, we'll deal with one thing at a time :rant:
For what it's worth, and maybe it'll help to clear the air a little, I did try to discuss the BR thread with all involved but with the exception of some foot-stamping nobody could come up with a proper reason for the chat not to come here. That's not me deciding that I'm right and everyone else is wrong, I'm not that kind of person, but nobody came up with a convincing argument as to why I shouldn't go with Plan A. Explain something and back it up and I have no problems being told I'm wrong, my missus does it all the time haha.
I know there is a bit of resentment and it probably seems like I'm out to stamp on people's fun or do the old stereotypical "internet authoritah" mod-power thing, but I'm honestly just trying to look at the Qld section, as a whole, and do what's best for it. It will probably cause a few waves, most changes will, but I am genuinely trying to do the right thing.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
