You've been coming out with some doozies over the last couple of days Brandon.
suuuuuuuuuuuuuuuuuuuuuuuup dan?
so er...Hello? Anyone in here? much going down?
im here :rant:
epic storm going down atm her in indro - lights flickering n shit
It probably should be merged as well, it essentally doubles up on whoretown as well
mate just got off the phone to greg at gktech they have new radiator bottles coming in on the 29th - wana grab a couple? save a little on postage?
Lets get that shit done then. Get some more people in this here empty vessel.
im here :rant:
We had our big storm already. Pissed it down and cracked one of our down pipes. fun times ahead for tomorrow. Tristan you coming tonight?
how much are they asking?
umm they are $39 each - havnt looked at postage - probs $5ish each i guess
na mate no deal from me
You suck. What's the news on the 180? Bought all the fuses I needed for the 31 yesterday and had a fiddle around with stuff. Needs epic rewiring so not looking forward to that. I think I'll do it after christmas.
will have to consult with Anna and see if she wants it, when do you need to know by?
no rush bro - i just bought on 2nd hand on boost for $10, so anytime man - probs after new years? (depending on how shit this 2nd hand one is :rant:)
180 is chillin, had a whole bunch of stuff delivered today :(
some parts are chilling in customs - should be good to go tmr :happy:
and engine mounts should be here thursday, HOPEFULLY
nice mang. Still need to sort out a cat for the 31 and then once all the electrics are working will get a rwc and register it. then i can gut it, minispool, s13 coil overs and turbo and then away we go. hopefully it will be all finished by the time I get my license back haha.
Col - Fair question mate, and yes it's something I'm already looking at.
The main reason that thread wasn't gone a long time ago is partly for the same reasons the BR thread stayed for as long as it did, but also that they're a good two hours north so there was some justification in having the separation. From memory that's how it was looked at last time it was discussed anyway.
But yes, I agree that realistically the chat in there should probably be moved into WT as well. They do have the added complication of being well out of the Brisbane metro area but talking crap over the internet isn't really dependent on location is it, lol.
In any case, we'll deal with one thing at a time :rant:
For what it's worth, and maybe it'll help to clear the air a little, I did try to discuss the BR thread with all involved but with the exception of some foot-stamping nobody could come up with a proper reason for the chat not to come here. That's not me deciding that I'm right and everyone else is wrong, I'm not that kind of person, but nobody came up with a convincing argument as to why I shouldn't go with Plan A. Explain something and back it up and I have no problems being told I'm wrong, my missus does it all the time haha.
I know there is a bit of resentment and it probably seems like I'm out to stamp on people's fun or do the old stereotypical "internet authoritah" mod-power thing, but I'm honestly just trying to look at the Qld section, as a whole, and do what's best for it. It will probably cause a few waves, most changes will, but I am genuinely trying to do the right thing.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
