FBT = fringe benefit tax
You have to do a minimum of 25,000km per annum to slip under the 11% tax threshold on a leased car...
In short if you do 24,600km for example in a year you then have to pay 14.5% tax for the value of the vehicle...
So in my case that's a difference of approx $2000
Meaning if I hit my km's target I pay nothing more, if I don't hit the target I have to pay $2000 extra tax...
Ive never had a problem doing 25k a year... However I just came back from 7 weeks annual leave an did not drive the car at all while away...
So I have a compiled problem once I returned to work... So I needed 2500km on it ASAP...
Now I am within 800km of the disposal target with 9 days to do it... So 100km a day and i'm all sweet now...
Seriously? 25000ks?
I did 15000ks in the past 4months.
I usually tend to avg about 4000ks/month give or take.
I should get a lease vehicle for work. =D
I like claiming the maxima\, i mean skyline of tax though. hmm..
Edit: Woot! 50th post!
Edited by Tony350
my 3 year old nephew does 4 weetbix...
i eat bacon... nuf said
Eh, its one of my 5 meals a day, heavy breakie makes for a sluggish start
I'm sorry.......
I just don't like soccer!!
There, I said it :verymad:
So boring
