FBT = fringe benefit tax
You have to do a minimum of 25,000km per annum to slip under the 11% tax threshold on a leased car...
In short if you do 24,600km for example in a year you then have to pay 14.5% tax for the value of the vehicle...
So in my case that's a difference of approx $2000
Meaning if I hit my km's target I pay nothing more, if I don't hit the target I have to pay $2000 extra tax...
Ive never had a problem doing 25k a year... However I just came back from 7 weeks annual leave an did not drive the car at all while away...
So I have a compiled problem once I returned to work... So I needed 2500km on it ASAP...
Now I am within 800km of the disposal target with 9 days to do it... So 100km a day and i'm all sweet now...
Seriously? 25000ks?
I did 15000ks in the past 4months.
I usually tend to avg about 4000ks/month give or take.
I should get a lease vehicle for work. =D
I like claiming the maxima\, i mean skyline of tax though. hmm..
Edit: Woot! 50th post!
Edited by Tony350
my 3 year old nephew does 4 weetbix...
i eat bacon... nuf said
Eh, its one of my 5 meals a day, heavy breakie makes for a sluggish start
I'm sorry.......
I just don't like soccer!!
There, I said it :verymad:
So boring
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
