  • 3 weeks later...
$1 AUD = $1.29 NZD
So i make a little more
i still feel you should just go there with 15 aus dollars, and the flash that, family guy style
they will make you their king, and worship the very ground you walk on
Morning Mangs,
TFIT. Ikes Cream Tonight :bunny:
Stupid POS car wouldn't start this morning. Had to drive the ute and made me 15 mins late to work. F*ck 31s.
Shame we don't have $1 notes any more...
does anybody know where theres a diy coin op car wash joint around spring hill/valley/new farm area?..
kinda new to this area and never noticed any while driving..my car needs a wash badly..
You'll be lucky to find those types of car washes these days. They do exist but are very rare.
There is a good high pressure touch-less auto wash at the BP on the top end of corro drive just past Toowong shopping center, take me car in it all the time works a treat not cheap @$18 for the top wash
There's one on the south side on logan road in the greenslopes area i think. Haven't been past that way for 6 months though, not sure if it's still in business.
Yeah thats still there just up from greenslopes shopping center opp' birdwood st, I forgot all about that one
Edited by Oz
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
