I'm happy to go anywhere. I'm part of a Car Club and we're meant to like driving...
What's wrong with Indro, Toowoong, StLucia?
I love driving (opens are so close I refuse to drive mine ATM lol)
Nothing's wrong with it, i just spent alot of time around that area with the ex, and I tend to become a grumpy shit of a human if I have to travel through those parts lol
OH I see. What was his name? :yes:
Boweling sounds like a good plan, north side of the city would rock :P then all you toowoomba folk could cruise over the mountains to get there.
No idea where a good one is up here, only bowling Ive done of late was in the middle of the city.....which is a silly idea
Keen. What's a good place up your way Bodo?
I see what you did there
Yeah I did.
Bowling.... we need to go bowling :yes:
Also what the hell are u doing sleeping at 9pm
Yeah bowling is ok.
And I was asleep because I am old. Just like I am awake at this hour, be ause I am old.
Yeah bowling is ok.
Yeah bowling is ok.
Yeah bowling is ok.
Yeah bowling is ok.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
