Great weekend. Curry & car wash with mike. Then went to a mates birthday - with mike. Then cruise today - with mike.
Just had KFC and now watching Space Jam then pass out.
Don't know how you can put up with that guy...he is such a dick.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
