Sure about that? I had three bishes hanging off my doodle.
Sure sure
Why yes. Yes you do. You, my gimp, are a marvellous catcher. :P
Why does Michael get sexy time and not me!
Nah.....must of been on pick on Tony night 2nite.
Poor bugger must be terrified.
I'm certain Chantelle can cook a superb meal.
As for you Cap...seatbelts on planes well....if the descent is any above 1000m kiss your ass goodbye as a seatbelt is gonna do F all!!!!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
