well that's not good mate. whats wrong wid it?
Timing belt, timing, rear k frame bushes, new front and rear racks, salve, brakes all round and drains the overfilled gearbox (got 2 liters out of the filler bung and it looked like liquid aluminum.. In other words he needs a new gearbox)
And that's it so far.... It's his first car
Where do I get the forum business cards?
Sadly not burnt... The rain didnt let me :(
Hi boyfriend :P *annoying girlfriend voice*
So this is what an awesome forum looks like.
Okay guys... I'm new to whoreing, give me a run down??
You should see all the dents and razor scrape marks from taking stickers off
And the gay 17 inch chromies.
He bought it in that condition. Has a rb20 silver top with all turbo manifolds and blanking plates bolted on
Didnt I just explain this?
Basically come here talk crap and hang out... The more you hang out the bigger of a whore you are, *looks at post count* I believe I'm qld's most infamous whore :P
No you're QLD's most infamous member...sorry most hated member ;)
Infamy... Fame, Depends how you interpret hate. Usually interpret it wrong, hence in my mind you all love me and my v8 ramblings lol :wub:
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
