.... I also like the fact it farks people off to see it in a skyline lol. Some people want to watch the world burn. I'd prefer to just mindf**k society into a pseudo feeling of security, then douse the thing with fuel and light the sucker up, I don't think I'd even watch, just simply walk away with my back turned victoriously humming Beethovens 5th :)
Why do u want the 6 speed? What's wrong with the 5 speed in yours or is it an auto?
And yes I love autos, for numerous reasons... 2 mainly: people ALWAYS will underestimate an auto car (if they're misinformed nimrods) and nothing amuses me more then taking someone for a run in mine and watching them go "WTF as it smashes into the next gear" or better yet all the "manual heros" that lay shit and then make excuses when they can't launch and "miss gears"
mmm sequential makes this not happen!! still saving for mine :(
hahahah i love it.
mines manual, just in 5th gear it idles way to high for highway driving and in 2nd gear the is not alot of grab it just..... kind of slowly drives away even when i hold revs up and stuff it then grabs, loses traction, and does its little 1 second wheel spin before i back off again
im thinking the s15 or the 350 gearbox i think from looking around the s15 box is weak and people put the r33 rb25 box's in the s15's
but im yet to convince myself of the need to, if the clutch starts to go then i may look more but other than that ill just spend more money on fuel hahaha probs be cheaper
Edited by cowdy
fark autos specially powerglides....no good on the street or pretty much uselss! my car is a street car and sees corners.... :P
If I was making big power I'd out a glide in mine :P I think gummy had one in his toranna at one point #@34GeeTeeTee
Yep 4.11 diff gears will do that, I've got 3.7s in the ass of mine.
I honestly don't think it's worth the fuss man, could always change ur gear ratio, and give me your 4.11s :)
im probably going to talk to northside transmission tomorrow they are a few sheds up from my work, i need to get my diff redone its leaking and the limo isnt so limo anymore.
ill see how much it would be to change the ratios or what they think of the idea of a box swap. if they think it will be worth it and its not to much i might let your nissan have some more nissan parts again :P
me to night all
Edited by cowdy
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
