Rightyo.....just got home and wasn't very thrilled as just before I came to the end my street my daughter decided to unstrap herself from her child seat and open the farkin door whilst I was drivn.....SECOND TO BIGGEST FARKEN SCARE EVER!!!!!
But I've since calmed down and cracked a open a beer
Edited by Ants
I'll marry her if he doesn't. I have all the F&F movies, plenty of coronas in stock a 32 GTR Vspec in the shed and over 100 model cars of skylines...... Ladies contain your orgasam's
Ill marry her :P I have all the movies too :P plenty of rum and a 33 out front she can drive of she wants to hahah :P
I CALL DIBS!
I CALL DIBS!
NO DIBS IN WHORETOWN
Pfft 33, 32's are where it's at. Everyone loves my 32
OMG model cars :P
And that's just what's in the cabinet
Can you believe it ladies, I am single haha
Chris is that suppose to be a pickup line? Because that's terrible!
Nice model collection though and your R32 is sexy
Edited by Ants
Pfft bishs love my 33
No they don't. They try and make you sell it :P
In the car with Zac and he says your collection is impressive and GTRs are always sexy
Damn straight. My GTR doesn't see the road much these days :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
