I just built a Ferrari
Bed
you almost got me there......but Im disapoint, why not a skyline bed for Tyler?
Farkin forgot to do a coke order, f**kitol
Nick, Nick, Nick, Nick. ur just makin ur stock take easier arnt ya
look what ever they do in the supply cupboard is none of your business :thumbsup:
LOL......as long as its filled wid da right stuff Zac ;)
I think that has come about Tony, and we are seeing more women present in the workforce than ever before. The is issue comes down to not having adequate laws to reinforce and support equality in the workforce.
one topic that pushes my buttons.
women want equal rights, but then complain that men are too rude in the workplace.
some of the female employees dont care, but alot do, and they enter the workplace more or less demanding men change.
how is that equal?
now more than ever, youre not allowed to say sexist, or racist remarks, no jokes to be played.
every day, it becomes more and more just a job.
/rant
I hate working with females, being they're superior I find it hard to enforce myself as I can't get pissed off at them in the way you would with a guy.
I miss working with Harley, that poor Kent would get told he was "f**king hopeless" 8 times before we even opened lol
how is that equal?
/rant
Exactly! "I want to be treated like an equal, yet ill only do 3/4 the work and expect all sorts of benefits."
Dafuq?!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
