Hey guys,
Imagine you racing a hyundai excel, fully stripped with a sick half cage all up in there, haltech screaming orders at those little injectors, garrett turb totally spooling hard out with some anti-lag, coilovers all round (dampeners turned up? Uh yeah of course..), a straight through 5" exhaust and the fattest AR bars you've seen. Have I got your attention yet?
Over the past 5 years I've taken part in many motorsport activities.
At the age of 16 I successfully completed the Isle of Mann superbike race, coming in at 6th overall with a overall speed of 296kph.
By 17 I'd managed to qualify and gained entry into V8 supercars, but study dictated that I was unable to compete, so instead I purchased an R33.
I've owned a Skyline for several years now, I've never had a fine for anything, never crashed or even come close for that matter.
I know the roads can be tough for someone repping the Hicas, and I also understand how much of an inconvenience having a terrible turning circle can be if you're out getting groceries on the way home from the track and have the good old lock bar.
Over this time I have learned how to avoid sliding off the road and requiring a tow out of someone's front yard.
My extensive skill basis has allowed me to drive at 70, 80, even 100kph over the speed limit without endangering a single person around me, or my wheels.
I've got a special offer for all of the SAU boys (sorry, no girls).
I will teach YOU how to drive like me. Say goodbye to fines. Crashes? Never again. "What about defect stations" I hear you say. I will even teach you how to lift so you have some beautiful breasts to expose while pulled over (they'll be looking at those pecs, not at the car, trust me, I've done it irl).
I'm prepared, spurred on by a friend of mine recently crashing his skyline, to offer you a GROUP CLASS!
Don't hesitate, PM me NOW to book in! For the low low price of only $50/hr, you'd be mad not to!
I'll even go a step further, book in with a group of ten or more and attract a 10% discount!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
