Can anyone recommend me a basic trickle charger to keep my battery intact when car is not being driven, as it struggled to start the car last night after being off for about 2 weeks
apparently or Pals at super cheap have one.
yeah at least it's overtime if anything happens after 5 or over the weekend. Even if I just answer the phone it's about $250
Geeze that's not bad, I like Saturday work. Puts me on $36~ an hour. If I can do I Sunday it's gona be a good pay slip lol
Hook jumper lead a to terminal n and jumper lead b to terminal p. proceed to attach the remaining ends to your testicals.
Car should remain charged for the rest of your life ;)
Their website says that have many, but what's the difference between a $69 one and a $219 one?
Don't really wanna spend over $100 for something i wont use often
On Call, is great. I make double my salary from on call.
It would be annoying though, no beer etc
If I work on the weekend I double my pay compared to if I just did it during the week...
No beer for 7 days at a time but every time the phone rings thats $85 and if I have to even start the car that's $190 minimum.
not bad my ot rate is about $155 an hour but it doesn't really happen all that often. Wet get paid some pissy allowance too but I think it's a around 40 bucks. Not really worth the hassle, you just hope to get a few calls that don't result in going out lol
generally, the cheap ones are an outright charger only.
the expensive ones have the trickle charge function.
or, take for good drive.
then, disconnect battery.
stops anything draining.
if you want to stop it completely, will have to find whats draining power.
yeah I disconnect. However I don't have a radio or clock to worry about resetting
Though when I went to Gladstone recently I racked up 34 hours of ot in the week. The tax man came at that pay packet like a spider monkey.
I paid more in tax last year than my wife made, I want a dole bludger as my butler for that shit.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
