So the cops just came to work and asked my why my car was on the side of the road....
Hmm let me see, because it f**king broke down and I had to get to work!? Ya dumb bastards, I have no intention of leaving it they're to rot!
f**king morons
Maybe, "see to it that the car is removed promptly"
.... Yes officer flamin mongrel knuckle
Should of told them 'to see to it that my car doesn't get broken into instead' I can think a billions better things for them to do!
Wow, they bothered coming to your work for that? My skyline broke and was sitting on the side of a busy street where it was a tight squeeze to get past. Was there all day whilst i was working and i didnt hear anything
I know! I was waiting to get fined for it. It's on a f**king back road 5ks out of town on no danger to anyone
When I had the black c210 I parked it the front of a unit complex in woodridge(yeah, I know) and within 2hrs of it being parked I got a call from the popo making sure it wasnt stolen amd informed me that its not a great area and that I shouldnt park It there if I cared about it... some cops are nice. Not many though
Went passed workshop today. Much happier I must say :yes:
1. I received the insurance proceeds in full
2. engine is finally starting too look like a complete engine (hot side almost completed) and looks awesome with the Mines dump pipes (no pics) sorry.
Why you no get pics, I say this because I would have sex with my dump pipes but no one ever gets to see them
Edited by Bunta
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
