Yeah, gotta make the coin to pay for the degree's to make the coin. Respect on the double degree that will require some serious dedication.
Well kinda, I'm 21 this year and should be graduating, I've finished 2 years of it of the four.
But I love by myself, own my car which has cost alot of money, own alot or guitars and hold down two steady jobs :/ ... It's a living lol
Lol you Wally,
I was going to go to TnT but my son can't do passenger rides.
Yer I instantly thought "goodbye abomination :(" I change gear as I went past the interesting a he would of saw was red and black and sideways... f**k local coppers are lazy
(Maybe they didnt think they could catch me muhaha lol)
Maybe they though the poor guy has already suffered enough
Nick you know better. Don't make me come over and beat your ass with a wooden spoon!
Finish your degree and hunt for a job you like. Business and commerce is a plenty but jobs are scarce and competition is tough.
As randomhero83 mentioned degrees are not everything. But I'm from a family if academics and would be lying if I said they do not matter. Just remember hard work (study) pays off!
Does anyone know where I could buy a single Ball bearing Ball of certain size?
Also, could someone please measure the ball size of a turbotech boost controller?
Also.... I have an excuse for the drags now, my boosts were being stolen!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
