I watched it yesterday too, managed to find a good copy :whistling:
Was a better movie than I expected, did nothing to stop me from wanting a charger or challenger
Does anyone here have any recommendations for the servicing of every day cars within a relatively close radius of the CBD? My sister is blowing up about having too go to far to have her cars done, She lives at new farm so the closer to there the better.
Any one got any experience with anyone in the area.
Lol,
Yeah as i've said to others, i think i'll always go and watch an FnF movie, corny as they may be with the 120 gear gear boxes and endless supply of oneliners i still enjoyed it.
This latest one seems to have filled the gap as best it can between all of the other FnF movies including Tokyo Drift.
That said, i'm a little unsure about Jason Statham... good actor, but doesnt seem like the movie franchise to bring him into.
I was alarmed at my number of posts too, If you combine here and SAUQLD, which are posts I would have made here had the other site not existed, I am at almost 30,000. What am I doing with my life :( lol
Anyone know what kind of laws govern the use of any form of Camber on a street car?
Survival of the fittest. If you have stupid camber and not enough tyre on the ground and can't get away, it's your own fault when the masses chase you with pitchforks and torches :P
Come now Tony, i'm allowed to be curious!
Besides, i would like to run a little bit of camber, just enough to assist the rims in tucking correctly when underload/cornering
At some stage i will probably get a slightly smaller offset rim, but it would be nice to have my current ones not scrub when climbing uneven driveways etc...
I've heard 3* is the most suspension places will dial arms in at... Weather this is true or not I don't know.
Also camber ftmfw, I run my front camber arms maxed out you know... For extra hectics lol. And my rears are fairly angled as well :)
downloading top gear now :)
Woo top gear night! :)
I don't think there are any laws on camber itself. HOWEVER. when looking straight down from above the car, the entire tyre (including at the bottom) must be inside the line of the guard. So having epic offset and using camber to tuck the front level/inside the guard, but leaving the bottom outside the guard, will not be legal.
Good to know.
I do need to get another set of rims at some point lol, when money permits...
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
