Just trawled several pages of slarting... Most interesting fact from it all was I was 5th highest poster for the day
Morning all
if you had of hung with us, we could have changed that number.
I dont know, 340ish posts, I think thats slart territory.
Yer that's true, best I ever went was somewhere in the high 200s (278 or something like that, probley a year ago with the new guard)
But we never page spammed like that so, I'll give you a 10 for effort and a 6.5 for execution.
It's obviously an abbreviation of good night but you aren't wishing someone well...
neither is 'good night', its more describing you own night.
so, 'night' said in the right manor, is the same as 'good night' also said in the right manor.
it implies the wish for their night to be good.
thanks.
itll go waaaaaay back down today.
damn work. :dry:
Yesterday's 50 would be my best surely
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
