Ok, I was going to say if you wanted launch type antilag, I know of a way, but for shift type antilag, I would suggest just using a ign cut attatched to the clutch over say...4k rpm. As you already has teh antilag, I will close my word hole
I had the option of running 98 and launch control or e85 and ALS. I locked in 'B' Eddie.
So we have roadworthy station inspectors here
And zeke told me that there was a skyline stolen from a car yard down the road (had seen it there many a time)
So I'm pretty sure I'm gonna leave my car in the workshop at night for the next few weeks.
Might have to go for a visit to chris
Where is 'here'?
Providing you have a spare programmable input I might be able to give you both. Ill get back to you on that one...
Pretty well the only thing it needs now is track-time and more talent from the driver.
ha ha i freaking love that guy, for some reason every time I see the picture I lose it lol
I need to combine him with what I'm calling my "classic" avatar, though not as old as the SDU humpy man, more recognisable.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
