No. Because even a few beers costs a shit load now. Until I have have everything I require I ain't going out.
Otay. :(
It's true though. Unless you start at a happy hour somewhere and smash the beers, it's freakishly exxy!
So compared to back when you guys left the mother site, how are things now?
I have no idea. The issues that effected us then ate no longer relevant to me so I can't really know. As long as it's working for you guys its all good.
Also, I haven't seen Josh post here in about a year and he's still in the top 50 all time posters.
Josh also lost 25000 posts when someone reset his stats. This is why when folks talk about being whore Kings I lol
HO LEE f*k!
What's the story behind your 4M?
By default, the system bumps up post count by 1 for each post. If this was changed to 100, 10,000, 500k, whatever the limit is, you could have bumped up and flown under the radar.
But then, how did josh lose 25k posts?
Josh lost the account, hence the posts. Where abouts is this list of posters?
Morning all.
Lastnight I had a Heineken and margarita?
Look on my book face for where i was tagged at and that's where it was and my sister tagged me tony so :P hahah
And nah zeke I think ill last I'm working on Kathryn's new car today. And I wanna finish my sub wiring
Swing past in the arvo or morning tho?
Tony I think we need more track events. What about a sau qld coast cruise? Go down to the Goldie in the morning (lock your cars) have some lunch (make sure cars are locked) and the do whatever? (Probably sit in car with it locked) then cruise home
Morning all.
We just did a Gold Coast cruise...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
