What do you want to do with the Unicorn? We've got a number of sprints and runs coming up post-AGM that could be good for it.
Cant afford to do any of it properly. Tyres, Brakes, ect all make track days way out of reach
have to agree with you. I'm actually thinking selling my AO48 because track days are going to be limited for me.
Few of you guys might have seen this floating around over the last few months. 1988 Mira, thoughts? I reckon with a bit of love and attention if would be a cool.different cruiser
I would forget this and with whatever cash or funds you were thinking of using to acquire this mini ice cream truck, spend it on your car instead.
Im looking for something to drive daily. Unfortunately the skyline can become a paid to drive on a daily basis at times and i lose my appreciation for how nice a car it is when I'm driving it around non stop
EDIT: Ice Cream Truck comes in under the $9k mark
Icecream truck could potentially be a PITA on a daily basis too I reckon. I cant imagine it drives real well.
fair nuff - but $9K is a fair bit for something like that. I reckon you could find and buy a second hand car in OZ for half that price and be in good nick. My Ford POS cost me $4.5k IIRC and is awesome (but not great for long distances)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
