because just straight up i want to :P no other reason than they look better and im going to be doing the gaskets soon so while off should swap. they look like a direct fit.
plus they i can fool my cluless mate that its a rb26 hahah
The plenum and throttle bodies will cost 500ish bucks or more? Then 750 to 1000 for the adaptor plate...which leaks half the time. Then you need an after market computer to run the different air intake sensors and tune wirth the itbs. The covers will probably cost another 500 ish bucks. The bonus is you will actually lose response due to the shorter runners on the plenum!!!!
Might as well buy a 26 instead. Surely there are cheaper ways to troll your mates.
thinking of buying some rb26 covers to put on the 25 and a plenum ideas thougths covers for sale...... ants?
I have an RB26 front cover which is black wrinkled coated. For the engine covers try the 4 sale section on SAU or import monster. Wrinkle finish is the way to go BTW.
Did you go for clear on yours?
yes that could probably help or most likely do the reverse and cause you endless grief
Look if someone can find me a bomb of a 33gtr.... Let's say for 15 and ill just rebuild it and get a daily
Possibly in like 5 years
Oh yeah totally forgot that you went with a whole new engine as opposed to rebuild. Did your old engine die or did you get to sell it?
nope engine was still in good nick and was able to sell it.
They are endless money pits IMO. Even after I get the car back there is still suspension to do, rear brakes, new paint job ahhhhhhh fcuk it its all too much!
Every car that you modify is an endless money pit, I have a mate who has spent more on his fourby than all of my cars combined!
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
