ladies.
ants, car?
Gav called me yesterday and fuel pump is farked!
Been in touch with my good friend Andrew from KMS and he is going to drop off 455ltr/hr Walbro in-tank pump to Gav this afternoon. The relay to the fuel pump also needs to be rewired. I believe that's it.
Gav told me it has oil pressure so that's a +.
Not good.
Better.
Bosch! Walboro...
:P
good stuff.
wonder why your pump stopped working?
mine sat 52 weeks, and worked.
fuel was ok to drive on too.
I want to sort out direct power to the pump, for more killerwasps
good stuff.
I found this strange as well. Haven't heard of Fuel Pumps dying from lack of use...
good stuff.
I will find out more once I speak to Gav.
I find it bizzare as well. Having said that fuel pump had not been used for 3 years. From memory Gav said as soon as he tried to crank it over the fuel fuse blew. Allegedly the fuel pump has been shorting out.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
