drooling over taylor?
So wrong. Can you just imagine the song that shed write?
Just a dopey boy
Loving a f**ked up toy
Took the abomination
And did skids everywhere....
And they went on and on and on and on.
Sung to Journey's Don't Stop Believing.
Can someone please tell me that it was well-composed? I thought that it was a masterpiece.
it was well composed.
srsly, wasnt too bad.
as soon as I read the on and on part, thought journey.
Ok Whores, opinions required
Looking at a soft roader type rig, it is to replace the Mazda, so 4cyl is preferred, we need it to be able to take us camping and to take Annas make up gear on location, so a little bit of off roading is required ie if its a crappy dirt road or crossing a horse paddock it needs to be able to do it mainly to save Anna haling all her shit around on foot like she has to now. The car will still spend 90% of its time on the road around town too.
I narrowed it down to a Forrester 2008 -2012 or a 4cyl Grand Vitara in the same years.
In terms of engines, external size and equipment they are more or less equal. Same price pretty much
The Forester is the more car like apparently, is 100kg lighter. The Low range is only 1.2 ish so not very low at all. Does have an electronic diff lock as well which is handy. Also comes with roof rails (swags can go up there) and a 450L/1600L load area. 220mm of clearance.
The Grand Vitara is more truck like, has a proper low range at 1.9, a faux ladder frame chassis, also has a electronic locker and hill decent assist. It has a smaller load area, 380L/758L and no roof rails. 200mm of clearance.
What say the whores?
if you go the subie, make sure to keep up the servicing with the upper engine cleaner.
you probably have, but have you considered xtrail or awd dualis?
dualis might be a little soft for what you want, but does have electric centre lock.
more car type.
just food for thought.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
