All good. Hope that it all works out mate.
Are you and Anna able to attend the AGM?
Cheers, it's all good so far!
No I don't think so. Anna leaves home for work at 4:30 in the morning the next morning, and me? Tbh I simply can't muster up the required f**ks, sorry. Spent way to long invested in the club and it's nice not having to care at the moment!
Mangs, scrackin round here?
Post for august. On days when work is overwhelming it is good to know there are people out there doing worse lol http://www.news.com.au/business/companies/bank-of-america-intern-drops-dead-8216after-pulling-allnighters8217/story-fnda1bsz-1226700509896
Went out to Leyburn sprints on the weekend and had a absolute ball camping, drinking and watching the sprints. There were some really interesting cars out there only 1 skyline though. That has given me more motivation to get the ute finished and out to some events.
That sounds good. I want to finally give the Gatton sprints a go next year. Have been trying for that one for 7 years to no avail
Good evening whores.
I need some advice. I put my 34 on gumtree for $16000 just to see what might happen. Anyway a guy contacted me & I went & met him tonight so he could see the car & he offered me $14000 cash for but I'm not to sure if I should sell it for that or not. I told him the lowest I would go is $14500.
stick with the 14.5.
worst case scenario, you keep your car.
Sick, Good news. What was up with the ecu?
when thery done the run in tune, I was told it was running 12.6v, and they didn't want to push it.
just checked, is running 13-13.2v.
so, should be all good.
didn't drop under 13.0 for more then half a second.
I wanna go fast.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
