I doubt that anyone's car here can handle 24 laps consistently at full pelt.
I'd trust the wedge to do 24 laps
I'd also give it a crack in the pinny... not because I think it would handle it; I just wouldn't care :P
I think I can take mine out to 6200cc (383ci) on a stock block, with a resleave I can go all the way out to 427ci (that 7.0L for you imperialites) :banana:
And I'd still destroy you around any racetrack
With all that is wrong with your car, you're worried about legalities? This calls for a roflcoptor!
What's wrong with my car, everything is legal and mod plated for it... (Except the wheel spacers and the shifter)
Willowbank is a type of racetrack... :thumbsup:
I like this post. I was going to bold the bits that I like then realised that I would bold the entire post.
Goes on power to weight, can legally go natro up to a 7L, can only legally do FI (fairy induction) up to 5.3L :(
Thats weird, I would back a 5L v8 like a S62 with a super charger or pair of turbos hanging off it to make more power than a natro 7L
Key word:
Also I keep telling you all, not that any of you listen.... I don't care about your stupid curvy looped roads, and the only time my car will see one is happy laps/power cruise
I'd beat you at that queer straight line stuff that you do too if I knew how to do it. There's easily more than 8/100ths or whatever the difference was it was in my shitty launches.
They would... The rules are f**king dumb, problem is when I built my car I didn't realise the laws.
Key word:I'd beat you at that queer straight line stuff that you do too if I knew how to do it. There's easily more than 8/100ths or whatever the difference was it was in my shitty launches.
thats nice.
would still take nicks over what ever car you have.
On this setup... Mayb.
On the next or the one after not a hope in lucifers garden
Hey Eastwood leave Paul alone... He has a cool accent and owns an ls1 :P
inb4 how does a victorian have a cool accent? lulz.
but for serial. qld on saturday. f**king yes. 16 days of beaches, hotel sex, golf, booze (a wedding, boooo) and good old fashioned redneck fun.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
