Not for me. I rarely use FB chat.
I wasnt talking about you, I was talking about Nick, but now from that reaction I am suspicious of you too :P
Hey Tony, You know what we should do next year some time? Morgan Park. Its a cool track and we could do what the NSW peeps did/do? with Wakefield, Road trip up there, track day, then stay the night and get on the piss.
It's on the cards.
Can't wait to roll up next to an unsuspecting McFly, look over and smile and watch his soul slowly die as I hit this button
I cant wait till the cops roll up, see that button, look over and smile and we get to watch your soul slowly die as they bum you relentlessly for hours before giving you your notice to appear.
Edited by Bunta
I cant wait till the cops roll up, see that button, look over and smile and watch your soul slowly die as they bum you relentlessly for hours before giving you your notice to appear.
Hide the button *herdererp*
Nah I'm gona put it on my steering wheel with a big label "NITROUS PURGE BUTTON #hectick"
Best of luck to you, but i doubt you get away with any form of it for long.
Lies purge kits are awesome, I would shit bricks a car was sitting at me next to the lights and next thing I hear and see this thing purge a nitrous line and the stand on a massive stall... Thing of nightmares
On the street you should be more worried about something that sees all that, Says challenge accepted, dials up 9krpm and side steps the clutch and disappears leaving only 4 little black lines. AWD grip is very hard to beat in a traffic light grand prix.
I know which one looks more impressive...
that to a child would be truely terrifying.
i need one. keep those damn kids off my lawn
Dude if you came running out of the dark all oggity boogity and dressed like that I'd shit myself.... So would 98% of people, the other two percent would die
The only difference is a puff of girly gas.
9Krpm launches, especially with a ignition cut limiter look and sound amazing.
Flames > fluffy white clouds
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
