I do like my rugby, I only stopped playing a few years ago
I opened batting with him
Australia or NZ for the Bledisloe? Honestly.
You're good at having a bat eh? McFly keeps asking me to come play cricket but I haven't played in years! Would like a few net sessions first.
New Zealand will win easily.
I am not any more, i used to work very very hard on cricket, Nets every day of the year and a batting coach twice a week leading up to and during summer. Then I stopped playing for 12 years and am fairly bad. 3 years of warehouse and I am slowly improving, but will never get back to good with out the time to put in like I once did. There will be some net sessions soon
I used to be ok. More of a batsman and keeper than anything else. It's more about the solid leather ball flying towards my bollocks and not having swung a cricket bat in 5+ years that concerns me.
Thats what boxes are for!
Been hit a few times. Still freaking hurts.
It's not getting hit in the man zone that hurts, more the upper thigh area.
I also wear a super mega thigh pad, early on it saved me some pain, but I have stopped getting hit there with such regularity lately.
This would help. I should really go buy a box and what not and start coming out. If I can get my fitness up, would probably be after the wedding.
No. One of my friends is and I'm party of the wedding party.
ahh i see, weddings are the worst.
Eh crickets alright, I'll watch it if I'm around cricket fanatics... I like 20/20 that's about it
20/20 makes me cry, but the casual cricket fan seems to like it so thats ok
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
