That was the value to the company. The client has basically stated that they only wish to deal with the Director and hence I'm out of the process.
Thats a bit ghey, and also weird, who wants to deal with the director of anything, they never know thier ass from their elbow
Sucks a fat one, It happens to the best of us.
on some good news looks like I have sold my Apexi PFC ;)
That's great news, Money back in the sky rocket.
In other news I have the next 2 days off, Who is doing what.
It's happening more and more frequently which is where my concern lies. This, and then another client saying that they are moving everything in house, on top of the fact that SFA firms are hiring makes things incredibly tough. Our Director is actually hands on and does a lot of work himself.
Maybe it's time to look into ways to innervate your sales process, What can you personally offer your clients that no one else can and what can your business provide that they can't get anywhere else including internally?
Mugabe blowjobs don't count.
I was doing this. I had really strong connections with a number of the Partners and then HR has just come in and killed it.
Lean a lesson that I have just struggled with learning: Sometimes you will work our guts out to get something over the line just for someone else to come along and shit all over it.
If someone else screw's your deal then it is out of your control, Never take shit like that to heart it will eventually break you.
If your customers are happy and your boss is signing your paycheck then take the money and run, Alternatively live the Australian dream: find someone to pay you more to do less.
All of the time HR are dicks, No one ever implements HR propperly and the Power mad generally take jobs in that area. (If I offended someone with this statement then too bad)
Beer n Bitches fixes everything, Take a holiday and do something you have always wanted to do.
It was that major firm where I had the relationships with the partners and HR was allegedly holding things up.
Seriously contemplating resigning.;
well you know what they say 'if you cant beat them'..............................nah fuark that. Theses days you have to fight for what you want. Do not loose focus on that and dont give up mate.
This financial year so far has been apalling. I don't know dude...
lol......but you could offer it.
Mr Ants is it time to start whipping people over your car not being done?
yep, why me??? WTF did I do wrong??? I havent even paid Sean anything........bad luck????
Well I've got something to say to you mr bad luck.............................................F U!!!!!!!!! you dont control my life.
Gonna have to call Sean and see what the G O is.............FFS :verymad:
Well it would pay for Seans tunning costs I would imagine.
I have Friday off as its a public holiday here on the GC so looking at tidying up the house and garage so I can make room for 1. the new bub to come and 2. that stupid thing nick named ant-eater
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
