I will break it down for you, because your arguments tend to jump around all over the place until even you no longer know what your point is.
You were talking about 'on the street' and because we all know that at most events you can do what ever you want and be legal I took that off the table. So my point was, that you can have fun in a good handling car and be entirely legal, Mt Nebo for example, if you are doing the speed limit in some parts you are doing well. It is never legal to do 100mph or bake your tyres at that speed outside of an event of some sort.
I don't base my statement towards skidzzzzzzzzzzz on safety. I am sure in most situations it is perfectly safe. In every form of motorsport that means a damn losing traction is a bad thing, not something to get all excited about, It just shows a terrible suspension set up. The people that tend to jizz over skids are in my experience backwards f**kwits whos cars are not actually good at anything else. Now before you take offence I am not saying you are a backwards f**kwit, just that when whoever it may be is carrying on about skids they sound a lot like the other backwards f**kwits I have known over the years who are into the same thing.
Um I don't know about your car but my skyline has 4 seats... Plenty of room for kev robbo and Shane
They dont like not having back windows to hang their arms out of though, Its also harder to yell at people as you drive by with out back windows
I have come to the realisation that I am going to have to take my car down to Sean to install the Link and get some sort of a driveable tune in there, then sell my power FC and AFMS to afford the crank trigger, then get it put on, then get the tune finished. This will lead to a bigger tuning bill and major ass pains with driving to the coast all the time :S
I am saying YOU cant bake tyres at 160km :P. I know full well it is possible
Hehe
Nah I can't put it on any more, I had to give it back to your dad.
If he was still alive I would have told him that, he was in the RLI so he probably would have had some interesting ways to kill you! :P
Dont worry, I am not one of THOSE guys who will get all cut about somthing like that. All good
I hope nobody takes anything in here seriously... Otherwise I've probley got a lot of enemies and death threats coming my way
I think people were shocked at the AGM when I was actually being helpful and making useful points lol
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
