Yep, at QR happy laps. Apparently I have a reputation for being a bit quick on mountains or something, I just think Tony overstates it. Also people tend to come off the road or get fined on mountain runs with me.
Taller guy thin build with sunnies on? Driving a R33? I think i remember you up my clacker though all the corners. car was sticking well to the road, well alot better than my boat anyway
Not quite thin but I'm working on it ;)
That would be me, I didn't have anywhere near the power to get past you on the straights but it was a lot of fun watching you slide round all the bends. Mine sticks alright till they tyres head up then it gets more exciting.
nice I e Scotty. It's not too windy for golf?
Yep. Hope those loud neighbours move out. I'm gonna mow the grass soon that'll wake them up hey heh heh.....
Yes, your car build will be interesting mate.
9am for the mowing to wake em up? your far to nice
I love detailed build threads in general, Ant's has an awesome one, Mat's just makes me jealous.
34 Shell shouldn't be too hard to find I would Imagine.
love to have stripped track car, any S or R shell would do the job nicely
we had the neighbours dog non stop barking from 11-12:30 last night. No idea how they can sleep through it and not tell their own dog to shut the f**k up. I thought they would gt sick of me yelling at their dog
airhorns at their bedroom window, train them to train their dog.
Straight line speed is all I've got
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
