excellent, i havent been up mountains since my car was stolen :cheers: (considering i used to go mountain running twice a week, its been a long time) it'll be weird not driving though.
what's Rohan's driving like? he quick?
bawahahahahahaha
light flywheel twin plates rock!!!!!!
haha i couldnt stand it personally, i need a clutch that i can actually feel whats going on! and that rattle would give me the sh!ts :D
oi shane...
check out the pics taken from that last photo shoot area last night -
http://www.skylinesaustralia.com/forums/in...t&p=2802414
seen and replied :cheers:
mornin karen :O
how was ur weekend?
Weekend was ok...not long enough :P
and to boot we are now back to full 5 days weeks :( :(
john i still cant get over how soft ur flamin clutch is! and it rattles like a dirty twin plate should :D
My twin plate is very unusual...you should hava go of it Shane...no rattles at all, and its definitely not soft :cheers:
Weekend was ok...not long enough :(
u have a twin plate? :O never knew that :D
john's is softer than stock! and the grab point is half way out! but i spuppose what can u expect from an NPC clutch :P
drove ian's car aswell, now that's a nice twin plate!
mornin all I just got my turbo hose from autobahn $90 ffs but at least I got one, now I just gotta wait till it cools down :(
fark terry that woulda hurt!
u have a twin plate? :O never knew that :cheers:
No of course not...I don't tell anyone what I've done to my car :(
u comin on the mountain run this friday nite karen? mite have a feel of it then, thats if u let me :D
Yes I am and yes you can feel it...and the clutch too if ya want :P
Guest
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
