Calendar fiasco???
well obiviously you havent seen the latest episode in the ongoing drama.
Let me recap for those with reduced/limited recall capacity, first we had a calender, it was organised and AFAICT ready for sale, but noooooooooooooooooooooooooooooooooooooooooooooooooooooooooo something happened and we were denied the opportunity to proudly display our club on our walls. not only that but we were left in the dark hoping against hope that it was going ahead, but nooooo again we werent even given the dignity of that information.
that brings me to the present day, after a lot of hard work by one person to try, it seems that it was all in vain, as I was eargerly anticipating the release of it yet again the thing has been once again stymied by......by well I dont really know this time which is no different from before.
Bryn says:
ouch
I am the real barbie girl says:
ouch like a minge with an STD
Bryn says:
hahaha
Bryn says:
u are random man
Bryn says:
really cute to
should i be scared?
Bryn says:
nah
Bryn says:
u shuld be turned on
my penis throbs
Bryn says:
hhehehe
Bryn says:
cut or uncut
Bryn says:
smooth or hairy
Bryn says:
top or bottom
*runneh*
Bryn says:
lol
Bryn says
Guest
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
